TDC57
TDC57's Avatar
04.18.2008, 05:27 PM
Originally Posted by xcntrk View Post
I think that’s probably a good start. It seems high initially when coupled with the Emaxx 2nd gear and 1/8 diffs, but when you combine it with that low KV Neu motor barely turning 30k on 6S, I think you could probably run whatever gearing you want and not have to worry about excessive heat.
Hay xcntrk!.. That’s what I', hopping for not to hot of an application.. I'll just need to keep my eye on the temps for a while and experiment with different setups. I'm glad to hear that at lest my starting point wont be a bad place..
Thanks for the advise..
Have a great one..
Shaun.
Nothing!.. Hahahahaaa..
