RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
09.13.2005, 08:32 PM
The hacker controller were known to be "smokey". Frankly, you are lucky to have gotten as much use as you did out of it. The discontinued those controllers quite a while ago because they were failing at a high rate. The motor should be fine, but you should run a fan on it to keep it cooler. A larger motor, like the 7xl would be a better choice for a large, heavy beast as well.
