04.20.2008, 11:50 AM
You know this 'feature' in the MGM controller where the actual throttle position determines the speed the motor is running at?
so if you go from WOT to 5 percent, the car brakes as hard as it can to make the motor turn at 5 percent.. it might be an explanation..
