MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
04.20.2008, 07:08 PM
I was talking about this setup in another thread where david was having troubles fitting the rear brake rotor due to motor clearance issues. I would think this setup would work well. It may take a while to get right though. The esc wouldn't get worked that hard either as it would really only be braking the rear wheels and they do less then half the braking anyway.
And What 83gt and entjoles said is how to do it. Mix the brake on your radio with the 3rd channel and plug the brake servo into that. Make sure you disable reverse as well.
