Batfish
Batfish's Avatar
09.14.2005, 09:27 AM
Originally posted by Papa
If I want to run two 10amp chargers do I need a power supply rated at 20 amps?
At least 20 amps continuous, yes. If you're running both chargers at 10A, I'd play it safe by going with a power supply that will offer up at least 25A continuous.
Remember to make sure that the number of amps you see on the power supply is continuous and not peak. I've seen power supplies that say they are 10A, but are really 10A peak with 7A continuous.
Joe
Electronics run on smoke... if you let the smoke out, they stop working.
