jhautz
jhautz's Avatar
04.22.2008, 01:30 PM
Just a thought... Here is a cheap(er) way for you to try and reduce battery heat and increase run time.
The Lehner motors can be reconfigured to run in eithe delta or wye wind by changing the sloder path on the back of the motor. If you change your 1930/6 it will become a 1930/10 at 2090kv. On a 4s pack that will give you around 30K motor rpm. You could run that on your MM and reduce amp draw a bit from your current set up and you could do it all with the ESC and Motor you alreay have.
BTW: I'm curious what batteries you are running. I run a 3s 3700mah Polyquest, MM and Hacker 8L (3019kv) and don't have any heat issues and get run times of easily 15-20 minutes beating it very hard. I actually have a 1903/6 here and was thinking about putting it in the CRT.5 to see how it ran.
to make it...
or break it...
Silent...But Deadly
