04.22.2008, 02:30 PM
Originally Posted by VintageMA View Post
...With the RCM extended chassis and 30 series wheels it seems the current draw has gone straight through the roof.
Well, the extended chassis added some weight, and the larger tires effectively increased your gearing, so that makes sense. I would've gone down at least 2 teeth on the pinion to keep close to the same roll-out ratio and to help compensate for the added weight. Of course, this assumes you don't mind losing a bit of top speed.
