Just go Play
Just go Play's Avatar
04.23.2008, 05:07 AM
There are a couple more changes that you should try that have not been mentioned yet.
1) Set your throttle and brake EPA settings on your TX to 120% (or w/e full throw is on spektrums), and then go through the initial programming with the ESC again so it sees the new settings. This made a huge difference in getting my 3PM to work right when I had problems with initial setup.
2) Already mentioned but worth repeating, set your neutral zone to 9% or 12%. If you don't and for some reason your neutrals center position changes the controller will not accept it and fail to start up.
Good luck.
