Originally Posted by Gallagher
Thank you for the reply.
Pleas send me your mod. pictures.
Is it easy to drill the revo shaft and with what size of drill bit?
Here is what mod looks like once it complete.
You need to use a 5/64 bit for your new Revo output shaft # 5366 / slipper application and will also need to remove approximately 7mm of the end. (I'm fabricating an output shaft for a budy of mine and will post before and after pics in a few days)
If your using a MOD1 spur you'll need a 27/64 for the center (for your 5x10mm bearing) you will also need to drill (3) holes bit size 13/64 for your clutch plate.
Here is great link explaining the process in detail..
http://www.rc-monster.com/forum/show...ht=MAXX+TRANNY
Here are some pictures of trans installed on chassis.
Hope that helps??
Let me know if I can of further assistance..
Have a great one..
Shaun.
PS.
You will a need drill press to drill all of the above holes.. (Sorry)..
