coolhandcountry
coolhandcountry's Avatar
09.14.2005, 06:54 PM
The 23 mm hex is what you need. I had same problem with stock plastic and metal hex. I have had no problem since went to the 23mm. The 40 mm is a little heavier. Depends more on the tire you choose. I have not noticed any difference in turning. I think the 40 series handle a lot better because of shorter side wall on some tires. A good glue job well hold well. Have not reglued a couple sets of tires. Hope this helps you out.
What kind of tires are you running or want to run? If weight is not an issue the bead locks work real well. Just add weight. The aluminum rims are heavier than plastic and cost alot more. Paid 170 for the 4 i have.:eek:
Peace!
Country
Help support the
Rc-Monster
Buy here
