lutach
lutach's Avatar
04.23.2008, 09:27 PM
Originally Posted by jzemaxx View Post
The black TT supra is no longer TT. Its now being converted to a single GT47-88mm turbo. Should put down around 1100rwhp or so.
Anyhow, back to the fun stuff...hehe. I tried fitting 4 lipo batts that I had laying around and 2 of the HV100 turnigy's I had extra. I don't think this is going to work..... So my question is what do you guys think would be the best way to go. Just run a single 1527on 12S or is their a different motor I should try?? I want 100mph out of this big buggy. I've seen 100mph+ RC's but they are all small, lightweight and don't look anything like an RC. Most of them use bodies that look like they came straight from wind tunnel testing and most are 4-5lbs max. That doesn't impress me, but I think small and light sure makes it alot easier to get these things to go fast.
You can try and see if 12S 2200mAh (4 x 6S 2200mAh) in a long style pack will do. The pack inside my truck in the pictures show how a 4400mAh 3S2P long pack looks like. That pack can be 6S1P for 22volts. Some places has good 25C and 30C 2200-2600mAh 6S packs. Thunder Power has the following: TP2600-6SXV, 22.2V, 6-Cell, 410g, 44x39x125 and $179.99 or TP2200-6SXV, 22.2V, 6-Cell, 340g, 51x33x107 and $149.99. You can also use the long type higher mAh packs like the following: http://www.kongpower.com/product_en/...pkind_recno=KP or http://www.airthunder.com/5000mah222...erypack-2.aspx. I know Flight power makes the long type packs as well. With the higher mAh pack all you do is put one on each side of the chassis and make a plug to hook up both controllers to them. The only weak link now will be the moving parts.
ID:	4462   Click image for larger version
