lutach
lutach's Avatar
04.23.2008, 11:47 PM
I have the 36-50-6S and to be honest, it's a beast. I thought it was 2900Kv, but when I ran it in my MBX5T, I noticed it was just sucking a lot of AMPs. Thant I found out it was a 5900Kv motor. First thing you have to do is to some how add screws or use high strength/temp epoxy to keep the front end from coming loose or you can use Mike's heat sink which will hold the motor together. You can see in the picture, the motor is more like 56mm long than 50mm stated my KD.
Name:	Motors & Magnets.jpg
ID:	4464   Click image for larger version
Name:	Motors side by side.jpg
ID:	4465   Click image for larger version
