azjc
04.24.2008, 02:23 AM
I have the Hyperion 0610i and my complaint was when I would try to use the balancer I would get the battery connection error, I called Maxamps where I bought the charger and they were no help, you need to hook up the charger, battery and balancer in a special sequence, I tried every possible combination and nothing worked...it charges fine when I charge through the bannana output jacks, and I balance the packs before I charge with a seperate balancer and I have had no problems, the first couple of times I did this I would also try balancing after charging, and they would be perfectly balanced so I only balance berfore I charge.
