tom255
tom255's Avatar
04.24.2008, 02:57 AM
Zippy-K seems pretty punchy sqweezing more watts from 5000mah 21C-30C than from 8000mah 10C-15C TrueRC battery but their rate are different too. Anyway I cant say anything bad yet, still have full capacity and no any puff sings after 10 cycles, BUT take a look on PolyQuest i noticed that price difference not big,Zippy-K ~$50 less by same mAh and 4S packs, maybe becouse I am platinum member... I dont know. But IMO PolyQuest worth extra money! If price difference is way more, Zippy-K are OK. I am pretty satisfied with Zippy-K (Check price difference then you are Logged in, personal price can difference from not logged user)
Turnigy ESC not suite very well to car, First its SLOW and have stupid delays second dont have Reverse/Brake-needs to use mechanical. If you plan to use on HighVoltage setup and do speed runs its OK.
Yes MMM is designed for CAR and if you want solid good BL ESC wait MMM and not cost so much if compare to other CAR ESC brands (MGM, Schulze, Quark etc)
I dont know about HC chargers dont have experince but on HC forum couple guys had problems with some sort of charger recommend to check forum before. And Like MTBikerTim mentioned Bantams bc6-10, Hyperion especialy 0610i have good reputation they are not so expensive and they are powerful!
