Originally Posted by aqwut
that would be your best bet man, then again, it's all about aerodynamics and Power:Weight....
Are my calculations off?? Or should 12S and a 1527 be around 4300-4500 watts?? The motor will draw 100 amps minimum I would imagine. Doing to math that should be enough to push the buggy at least close to 90mph if not more. Right now I'm running the MMT with only around 3600-3700 watts and its heavier and less aerodynamic, and its not even getting hot at all. So 1hp extra should get me another 10mph or more right off the batt with the right gearing, plus I should be able to gear up more from there. Maybe my thinking is off...
