sikeston34m
sikeston34m's Avatar
04.24.2008, 07:12 PM
Cheers dude!
I think I can fit some MOD1 gears -TDC57 is good at converting the old tranny to use the new 3.3spec slipper, so I may get him to make me something.
I wonder if you could get one of the new E maxx tranny input shafts, put it in a lathe, then turn the gear down to the same width as the input gear you're using?
Then drill and tap the 1st input gear from an original shaft, and attach it using set screws. Small flats ground on the shaft for sturdy landing points.
You'll have to remove the temper from the gear before you can drill or tap though. Then retemper afterwards.
Just a thought.
