04.25.2008, 09:46 AM
^+1. The stock reverse gears are quite weak. You have to be absolutely sure the truck isn't moving when you switch to reverse (which is the primary purpose of the Optidrive unit) or you'll strip those gears. At any rate, the FOC is required with the CD.
