04.25.2008, 11:25 AM
Originally Posted by Mofomaxx View Post
5000 mah 3s with the 1515 2.5D & MMM then ? I'm guessing if i get the gearing right & keep the E-Revo lightweight, which is my intention anyway, then from reading the "what's your runtime" thread on here 20+ minutes should be attainable with good performance aswell.....
I hope you mean TWO 3s (6s total) right? But yes, 5Ah @ 6s on a fairly light revo should be easily attainable. I get about 13-14 minutes of runtime with 14 GP3300 cells on a 9XL geared for around 30mph. You'll be running lighter cells and more voltage so you should be able to get at least 20 minutes.
If runtime is a little short for your liking, you may be able to dial in a little punch control to help reduce the huge runtime-robbing current spikes. Performance may suffer a tad, but you can play with the settings to get a good combination between performance and additional runtime.
