Thread: Mike's Li-SAVER
jhautz
jhautz's Avatar
04.25.2008, 10:36 PM
That'l do it. Glad to see you at least identified the problem.
I dont know if you have room, but try running 2 of those packs in parallel just to verify that a battery that holds voltage better solves the problem.
I think the reason the MM doesnt kick out is CC put a timer on the LVC in the MM. It needs to stay below the cut off voltage for a few seconds before it cuts out.
to make it...
or break it...
Silent...But Deadly
