Finnster
KillaHurtz
Finnster's Avatar
04.25.2008, 11:30 PM
Originally Posted by highflier View Post
I'll think about it. I am running 6s A123 (About 1/2 the voltage of the 10S guys)
Stock shocks, Wanderer motor, and a bunch of RPM stuff. The biggest issue is most likely the Suspension and where the weight is. I thought about coming just to learn and get some advise on easy improvementS to my truck. I have not run any of my equipment on a real track yet. Unless you count 15 years ago when I had a P.O.S. bandit that could barely make it around the track (No slipper or anything!!)
I'll watch and see what this develops into.
Highflier
NP, just to note tho, @ the RCM Bash I ran a 8xl/4S/MM combo on a mostly stock Revo, and if anything it was too fast. My 2nd race I used the Revo 2spd and barely got out of 1st gear. As long as you can make a 10 min run and do 30mph you are set.
