Originally Posted by mk351e
AHHH jzemaxx! I hoped you'd chime in! Your project is SICK (in a good way) with that there MMT truck!!!!!!!!!! But aren't you spinning your Neu motor past 60k?? and getting away with it?
I'm spinning a 1521 to right at 71K. Not something I suggest doing, and neither does Steve over at Neu, but I don't care if they blow up.....lol. For someone that doesn't want to replace them often, run them 60K or under
. Still will make TONS of power. Also the higher KV motors draw big time amps and will make less torque then a lower KV motor.
