04.27.2008, 01:42 PM
Originally Posted by BOOGIE444 View Post
Nice setup, I like how you use heat shrink tubing to attach the antenna wire to the side of the antenna tube, I do the same thing! I can never get my old beat up antenna wire to go through the tube, hell I cant get new wire to go through the tube either but thats another story
Well, if you put a little glass cleaner in the tube, it makes sliding the antenna wire through much easier.
That is actually masking tape I used, but I will try heatshrink now that you told me! I do have the wire in the tube, but there was alot of extra that I had sticking out, so I taped it to the side. I usually finalize my electronics mounting as I test a setup. I usually takes a dozen runs to get everything just the way I want it!
