09.15.2005, 07:19 PM
The Feigao 380 motors currently need an adapter plate, but there might be a solution for that some time (not sure yet). BK's website carries the Lehner 400-540 mounting plate, which would work with the Feigao 380 motors.
EDIT:
Just saw your other post.
The 6s will not run well when undergeared. It won't pull enough amps to "wake up". But at the "wake up" point, it is going to pull a lot of amps, and run time will be rather short (compared to other motors, anyways). The 6s won't accelerate like the SS5800 because the SS5800 actually uses a 400 size rotor, which can get spinning to full RPM faster because of less weight in the rotor.
