johnrobholmes
johnrobholmes's Avatar
04.28.2008, 07:06 AM
Sammus- the heat of a lipo pack is quite the interesting subject. Let us take one of my crawlers for an example. It is almost all amp bursts with average amp draws of 2-3 amps. The bursts can be upwards of 60a or more.
With a vislero 2100 pack I never saw it get very warm and punch was pretty good. I figured it was enough battery since it didn't get warm. Well, sure enough it puffed up on me from the half second bursts I was asking of it. Rated 15C/20C, probably more like 12C/15C
Then I got two 1300 25C packs from innov8tive. I ran them in parallel for 2600 mah. Logic would say that this pack would run cooler right? More power available, should have an easy time coping. Well, that was wrong. It actually ran hotter, I got higher amp draws, and I also got better voltage under load and MORE punch. Go figure. The lower resistance cells were allowing even more power and within a few minutes were getting up to 120 to 130F.
Now most crawlers don't burst over 35a very often, but you can count on a few hits per run and 25a is a frequent occurrence even on small ledges. Take into account that maxamps has been pushing this battery on crawlers http://www.maxamps.com/proddetail.ph...le-Pack&cat=82 and you can see where my issue arises with them. I have recommended to JAM in person that it is not big enough for proper longevity. His response is that it doesn't heat up, therefore it is plenty of pack.
