04.29.2008, 12:59 AM
If you run in any kind of a dirty/dusty area, you may want to seal those hols off IF you don't have any heat issues.
The MM should come with the programming cable (USB) and a disc to install it, then it will automatically check for updates. I think the current one is v1.19 and it should tell you what the version is when you plug it in to adjust settings.
Temps should not be much of a problem at all if you are still running NIMH, but if that's the case you may want to look into lipo's. Way more power!!!
There are a few debates as to what lipo's work well on the budget end, the zippy's are cheap and people like them so far. MaxAmps have the most complaints for their price, and Neu Energy (sold here in the RCM store) are a sure bet.
(going back to re-read your setup now :)
