DrKnow65
DrKnow65's Avatar
04.29.2008, 01:26 AM
You should be pleasently supprised at the difference the mega will make. You'll also come to love the MM programability. Sorry you have a bit of a wait till the used MM's start popping up all over the place. The wait to purchase it should pay off well $$$. You may even want to pick up the MMM (if cash is a non issue), it's a bit bigger than the MM but if you've already built a better ESC mount you may not have fit issues. Later on you could go to a higher voltage (~6S lipo) if you wanted...
Other thing is if you are using 3S you should also be using a UBEC, it will keep the ESC cooler too.
