rschoi_75
Certified Spaceball
rschoi_75's Avatar
04.29.2008, 12:37 PM
Originally Posted by Trick440 View Post
For the Diffs, just the cups like these? And this will help prevent the larger 'ring gear' gear from breaking teeth?
Large ring gear...
Photobucket
Diff cup...
Photobucket
Thanks guys.
As Brian mentioned, the cups will help the spider gears last longer. You still need to shim the pinion/ring gears.
On another note, you can use an alloy outer diff case as well, which will prolong the life of your ring/pinion gears:
rcm xt8
rcm xb8
rcm crt.5
