Originally Posted by BrianG
What is the oil thickness in the center diff? I'm thinking the front end is unloading too much and therefore letting the motor spin up too fast with not enough load.
7k in the middle. It definitely unloads on asphalt but when racing it seems to be about right.
Originally Posted by tom255
"If the motor is hot and ESC is cool.. GEAR UP!" its not realy 100% true rule. Its depends from many factors from ESC, ESC timings, oil thikness to motor that you actualy use.
I think oposite try to gear it down! And look then that happends with temp.
If you have smooth can, buy Novak HV heatsink you will gain some mins
I had similar problem and i thought that I am run 9XL motors and it was geared to ~40mph. Then I hooked EagleTree Logger I found that actualy this is 7XL mootor and with current gearing that I used it was geared to 57mph which it way too high.
Thanks for the thoughts. I have the 540C (finned) can.
Originally Posted by Mozzy
Did you try a 15T pinion??
When my mate was playing with gear ratios to maintain consistency with heat, changing 1 tooth made all the difference from a hot motor 80c to 60c just with one tooth difference.
MM, Maxxamps 14.8v 6000mah, Feigao 7XL.
Well right now I'm coming off at 100c and ideally I'd need to drop about 40c form that point. I haven't tried a 15t. I have the following options
16/46 (haven't tried)
16/48 (current - runs super hot)
14/46 (haven't tried)
14/48 (ran hot)
13/46 (haven't tried)
Any further suggestions? Thanks, guys.
-Jeff
