lutach
lutach's Avatar
04.30.2008, 11:45 AM
Go crazy like I did . I did the following: 2 sets of viscous in the garbage. 2 sets of 3Racing ball diffs http://www.thetoyz.com/cart/thetoyz_...&cat_name=MINI and stripped the ring gear, got extra ring gears http://www.thetoyz.com/cart/thetoyz_...&cat_name=MINI, but tried them with this http://www.thetoyz.com/cart/thetoyz_...&cat_name=MINI (Differential Pinion Gear GPM) and that failed. Got this http://www.thetoyz.com/cart/thetoyz_...&cat_name=MINI (aluminum center locked spool) and this http://www.thetoyz.com/cart/thetoyz_...&cat_name=MINI (MIP Hardened Steel Bevel Pinion Gears), it ate the ring gears pretty quick and waited for a solution. Got a set Atomic ball diffs http://www.thetoyz.com/cart/thetoyz_...&cat_name=MINI and http://www.thetoyz.com/cart/thetoyz_...&cat_name=MINI (Steel diff spur gear), but they didn't fit the aluminum diff cases. Are you guys confused yet. Well I am . So after the Atomic ball diff din't fit, I almost sold my MLST. I tried the Steel diff spur gear with the 3Racing and it fits, but locks up the diffs. So I put the plastic ones that came with Atomics diff and now it works and has been working great, plus replacements are cheap http://www.thetoyz.com/cart/thetoyz_...&cat_name=MINI (Replacement Ball Diff Spur Gear). I tried it first with a low Kv YS22-3000 and now I have the YC22-5000. So all you need to get is the 3Racing ball diffs http://www.thetoyz.com/cart/thetoyz_...&cat_name=MINI, Atomic diff spur gears http://www.thetoyz.com/cart/thetoyz_...&cat_name=MINI and MIP Hardened Steel Bevel Pinion Gears http://www.thetoyz.com/cart/thetoyz_...&cat_name=MINI.
Edti: more info here: http://www.one18th.com/forums/showthread.php?t=57034. They should make a sticky with this one .
