I had issues bolting the case (with the hinge pin carriers) to the chassis. I do not have pictures at the moment, but for some reason, one of the four large screws would just not go in right (everything looked like it lined up properly; all holes were straight looking and well...aligned, but I guess not?), and in the process of trying to get the screw to line up right, I stripped the head. Soooooo, now it's a majority of the way in (head of the screw is sticking out a bit, but I'm not going to worry about it; I'll just grind it down through driving on some asphalt for a while...
), but unfortunately, the head is stripped. All the other three screws went in fine (little difficult, but still went in just right).
I also have no clue how to get those small locknuts into the area where the shock tower screws into the tranny, so I left those out (I'm assuming those were for where the shock tower screws into the tranny at least). And what in the world are the larger locknuts for??? The actual case is great though. Smooth as can be! Mounting tended to be a bit of a pain though.
Any tips would be a huge help and thanks for replying!
