Serum
Serum's Avatar
05.02.2008, 02:43 AM
Check your driveshafts; they tend to bind against the shocks because they are too fat. check to see if you can see if they are damaged: scratched all around is what they usually do.
About the bulk; you can drill the hole a bit deeper (or through) with an 2.5 mm drill, and put a longer screw in it.
