SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
09.16.2005, 10:53 PM
Make sure you are in the "reduce rpm" setting. If you are in race mode or cut-off at 5v, the esc will cut power to the motor. Also, make sure both capacitors are intact. You could add extra capacitors and that may do the trick.
Area 52 Ranch Raceway
T.R.C.R.
