Thread: Venom BL System
Venom BL System
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
Question Venom BL System - 05.02.2008, 06:00 AM
What is everyones thoughts on the Venom BL System that will be coming out Mid May - Early June?
Here is a little run down on them
The Venom 120 amp Pro Brushless ESC is compatible with all sensored and sensorless brushless 540 motors as well as all 540 brushed motors and comes supplied with a programming card to allow you to adjust up to eleven individual parameters. Featuring a high efficiency cooling system that includes an aluminium heat sink and cooling fan to keep operating temperatures in check it comes pre wired with 14 gauge wire to ensure minimal power loss, has a compact footprint and works well in on and off-road applications. Venom have also released some competition 540 BL motors which are compatible with today’s most popular sensored brushless speed control systems, including LRP and Novak. The new motors feature CNC machined aluminium cans with ventilated front end bells, dual ball bearings and integrated cooling fans for high efficiency cooling. All motors have sintered magnets, adjustable timing, easy solder wire terminals and are fully rebuildable. Venom 540 Brushless Motors are available in 13.5T, 9.5T, 8.5T, 7.5T, 6.5T*, 5.5T*, 4.5T*, 3.5T* turns. (*includes integrated cooling fan).
Motors will be $74.99, ESC $169.99 and Combo $229.99.
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
