BOOGIE444
05.02.2008, 10:56 AM
Originally Posted by highflier View Post
I thought the kb45 was basically a wonderer XL motor. I guess that is not true?
I am still leaning towards the Mega 22/45/XX but I am a lilttle mixed up on KV's
The 9xl is 17XX KV the mega's are as follows
2500 /1
2100 /1e
1300 /2
I don't want to have to put a fan in my truck so temp is a big issue. My first guess is to go with the /1e version.
My second thought is to learn more about the kb45. Maybe if I buy a overkill motor but gear it to just meet my wants.. I could get it to run cool enough. Plus at the price of the KB45. I could put one of the wife's truck if the 9xl does not work out on 14.4 volts.
Scratch that... KB does not have a higher KV then the Wanderer :(
Highflier
The KB is a way bigger can than the feigao / wonderer XL motors. The KB has waaay more torque but it also has a 6mm shaft and a different bolt pattern than normal motors so a little bit of machine work is neccassary to make them work.
