tc3_racer_001
tc3_racer_001's Avatar
05.02.2008, 05:36 PM
thanks for that. im suprised your getting 15 minutes! i thought id struggle with even 5. do you use a lvc? i will buy 2 chargers, probably from the hyperion range, ive got a decent 30A supply, which will allow me to charge 2 packs @ 8-10A = 15 minute recharge, will my supply be powerful enough? (charge 4s and 3s)
im wondering if the 2 port charger would be the best option... its only 180W each side, but could probably hold the 10A on each side...
im using a modded antec power supply, with 2 12v outputs, rated at 19A each rail... if i only have one charger, i could only use one rail and possibly overload that one and cause it to blow. its running well, and i tested it for a short time and it took 22A of charger current (well i charged batteries @ a total of 22 amp and the chargers aint 100% efficient) so id guess close to 27A, before it dropped below 12v. the weird thing was, it brought the other rail down to about .5v above the loaded side, begging the question, are there really 2 seperate lines? and what would happen if i paralled the 2 outputs together... anyone tried this, as not even on computer forums mentions this!
sorry for hijacking,
ryan!
