tc3_racer_001
tc3_racer_001's Avatar
05.02.2008, 05:51 PM
Originally Posted by highflier View Post
Have you looked into Zip Charging. Your 300.00+ of chargers is = to my $20.00 setup when it comes to charging A123's. That said if you are going to use the chargers then I would go 7S.
Now back to topic. Tell us about the motors guys. Will I really be able to get away without the fan, Will I be able to tell the performance difference. What are the real world effiencies.
Highflier
zip charging hey? hows that work, ive seen it on youtube but not on 6s. please explain in here or pm.
im from the esavage gang. the people (kosta, possibly even bithed) have used this motor and were happy with it. i dont think its as good (from what ive heard) as a neu, but far far better than feigaos etc. 4 pole design will confuse some controllers, but MM will be fine. ill problably go with a neu created by castle... hopefully better than a feigao but cheap enough. id like to see them up against the REAL neus. if they are only slightly less efficient ill go with them :)
ryan
