DrKnow65
DrKnow65's Avatar
05.02.2008, 09:24 PM
Heat is produced by waised wattage. In other words your MM was acting like a 300watt heater and an ESC :(
The difference in the two motors is the pole count. The 2 pole motors don't produce as much torque but they spool up well and have good high end power. The 6 pole motors make tons of torque and bottom end power but the get less efficient at higher RPM's.
Lots of gear should bring the rustler around.
What settings were you running on the MM? I'm guessing by the sound of the lack of top end speed you are at full throttle and max rpm alot?
The teps should be fairly even for the ESC, Batt, and Motor. With the motor being a little warmer than the rest. Seems like 140*f is the max acceptable for all the components.
