glassdoctor
TEAM FUSION
glassdoctor's Avatar
05.03.2008, 10:15 PM
Smooth shaft on the Neu.
If you grind a flat spot, keep debris from getting into the motor. One good way is to use a good strong ziplock bag, etc.... put the motor in it and poke the shaft out though the bag. Then maybe even tape around the shaft to make sure it's sealed good. Grind it with a cutting wheel or sanding drum and take your time.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
