Thread: Race Bomb Proof
lutach
lutach's Avatar
05.04.2008, 02:35 PM
Originally Posted by Bomb-Proof View Post
I still have parts, but no chassis plates. "Cold Fusion" wanted to do all of my plates at one time, and said they could handle it. Turns out they only made 1 run and couldnt handle it, which left me with no machines set up to cut them anymore. I still have my CNC equipement, just nothing for the plates. I have alot of new stuff no one has even seen, but the second I show it off....its always on someones assembly line ready for sale. So, it becomes quite disgusting to come up with new stuff only to have it stolen and not get the credit/profit for it. Ive seen direct 100% copies of my stuff in magazines with zero credit from it. The only stuff I show now is the stuff thats a nightmare to duplicate, so atleast I will make people work for it. I started making lowrider parts (old school Impala's, etc.) and made stuff for $100K cars....stuff that was never done. Within a month, someone copied it completely, after I did the 6,000 lines of G-code to machine it. I have some really trick parts now, but have no intrest in showing them off to have someone copy em.
Are you still going to make your truggy chassis? It makes a fine HV chassis and I'm loving mine. Can you make the center motor mount and bearing support mount? I need 3 center motor mount. One for a normal 25mm motor mounting space for normal M3 screws, one for Neu that uses M4 type screws and one for a Lehner 22 series 30mm bolt pattern. I would also like the mounts to be around 5mm lower.
Regards.
