05.04.2008, 05:57 PM
If the ESCs are parallel, then DrKnow is making sense. The motor wires would be parallel to one another, so I would imagine it would still put out 4s power, but split the current load between the two ESCs and batteries.
I see what you're thinking though, but I'm not positive that it works that way (two ESCs outputs equals double the voltage).
Someone else will probably have a better answer/explanation.
