highflier
Emaxx- FLM wannabe
05.04.2008, 10:31 PM
Originally Posted by legobrains View Post
I would have to say the nomadio react for $260 at amain (out of stock at the moment) and with a coupon of 20 to 30 off would be the best bang for the buck radio.
I have the nomadio sensor. The react is nice cause it has enough memory to store the firmware for both spektrum and nomadio reciever on the radio. With the sensor I have to have my laptop and install the other firmware back and forth.
React pluses:
can be used as a joystick for windows PC (Like drive Need for Speed with it.)
Has enough memory to switch between nomadio and spektrum recievers.
No antenna to break off.
Has vibration to warn you of things like temp, voltage low, or laptime/ pit time
4 channel radio (everything else is only 3 channel)
Very easy to change settings, very easy to use menu
Sensor Pluses:
Has a back light screen so you can see in dark.
Has a very big screen, easy to read even while racing.
Can swith between spektrum and nomadio, but you need a computer/laptop to do it.
Has sound and vibration alerts.
I also have a futaba 3PM. My complaint with it is I have to have the manual with me just to figure out what the screen says. The abbreviate everything. It is hard to just reverse your sterring servo, or something simple.
I dont have spektrum stuff because I can't justify spending more money for a slower radio that does not give me telemetry stuff right off the bat.
DX3R costs 309 at amain. only 3 channel, no telemetry ($70 more), less model memory
React is 260 (on special right now, normally 300 and out of stock)
or you could get the react with out reciever for 189 and use some old specktrum reciever you have laying around.
I would really like to try the futaba 4pk some day.
LOL old spectrum reciever laying around. You nuts, I still have some AM stuff in use.
A few post back somebody said something about a DX3 they got with a free 2nd reciever. Any hints on where that deal is??
Highflier
