Just go Play
Just go Play's Avatar
05.05.2008, 04:54 PM
The kv of my neu appears to be correct as the rpms are correct for any given voltage so it's not mislabeled.
According to my MGM controller I see peaks of 185A on 5s but my eagletree v3 150A logger consistently reports only 125A peaks. Is there any chance that Mikes numbers came from an MGM controller? This has really got me curious now since there is such a large difference in readings between similar setups.
The spec sheet that came with my motor shows 1200-1500W continuous, 2700W@ 20secs 110A@ 20secs at max voltage 25v.
On 5s I pull around 2Kw peaks which I figured was in the ballpark based on the spec sheet. If I was pulling 180A that would push me up to 3.3Kw which is almost another 2hp. If that is where I should be do you think I should send the motor in to be checked?
