05.06.2008, 04:12 PM
Is the gearing maxed out because of the spur/pinion options or combined diameter? Don't know what kind of pitch that Tamiya uses, but I just replaced the stock Mod 0.4 pitch gears with 48p gears on my Evo III. There seems to be a very large selection of spurs and pinions with that pitch, and the switchover required no mods at all.
The M03 chassis has fixed mounts for the motor. It has 3 different sets of holes, for 16,18 and 20t pinion, but using 17,19,and 21t pinions yeilds a much nicer mesh. Tamiya use 48p metric pinions, and the 21t is largest that will fit. You must have a sliding adjustable motor mount on your evo, I have a dark impact that I swapped over to use a traxxas slipper (peg style) and 48p pinions and spurs.
Originally Posted by bruce750i View Post
I like your 2p deans connector. Nice and transferable. Is that hot glue for insulation I see on it? Sounds like one tough little machine.
You can get the same connector on tower hobbies from great planes, they have all kinds of deands connectors and adapters. I just made this one. Soldered the 3 deans together and then coated it in epoxy.
Originally Posted by DRIFT_BUGGY View Post
Something different I guess
It certainly is different. And fun to drive!
