SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
09.18.2005, 01:13 PM
Usually, the caps heat up when in use. If one cap is significantly warmer than the other, then the other is bad or disconnected. When I reconfigured my mgm 120, one of the capacitors came loose and I lost all servo control under acceleration and throttle control was way out of sync.
Area 52 Ranch Raceway
T.R.C.R.
