lutach
lutach's Avatar
05.07.2008, 11:53 AM
First run went ok for the speed control, but bad for the slipper clutch. The run only lasted for 3 or so minutes, but this Scorpion Commander can handle the 6S and the BEC was doing a fabulous job. Good news from Scorpion: They will add a bigger heat sink. Everything worked nice. Throttle response in good and I didn't have the "Motor Start Booster" on. Brake is also good, I have the soft brake setting on. It brakes soft like it should, but it's also nice to know if you want to lock the tires, it will if you grab full brake. I have attached a photo of the data and I have set the SPS to 50 for a more detailed graph.
Edit: Graph came out bad. Sorry.
Name:	MBX5T, Mega Acn22-30-2, Scorpion Commander 120A, 2 3S 2200mAh (22.2v)a.jpg
