highflier
Emaxx- FLM wannabe
05.08.2008, 08:42 PM
I was kinda thinking the same thing. 1 set of hardware.... Or maybe a heat sink only change, but use the same Circuit board. Just like now you can load firmware, just change the CC link to have a Drop box. Plane,Car,boat,Heli.
The single design will have to support worst case spec on each of the items. Or perhaps you just re-rate it based on use. I.E. Car only rate it at 100 amps, (due to surge) plane you rate it at 125, and boat with cooling maybe you can rate it even higher??
I know I used term of "just" and such that makes it sound easy. There is always complexities, I work in the Video game field and trust me I know... People are always telling us just do this or that, and it is good idea but hard is heck even though it sounds easy!
Highflier
