Originally Posted by BrianG
Is the embedded extractor at fault (maybe not completely Vista compatible), or is the whole file corrupt? Depending on the program, you might be able to manually extract the files using something like WinRAR.
Just a thought...
I am also using XP sp2. Thanks for the tip, but I'll just screw something up if I try and mess with manual extraction and whatnot
