Originally Posted by FG101C
How easily did the case come apart? The reason I ask is my Sidewinder case came apart a couple times at the track, the cases are identical in the way the two pieces come together.
Seems to be a solid case design... there are lock tabs on all four sides. It's easy to take apart but with 8 tabs I think it should hold together very well.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
