cemetery gates
05.10.2008, 10:53 PM
I had the same problem. You are not using a savage X skids are you? I believe that the kit was designed around the savage X in which the skids are shorter than the previous 21/25 savages. All I did was trim the skids to fit. No Problem after that...
Hope this helps!
