Thread: need crt help
05.10.2008, 11:04 PM
Take the 4 screws out of the spur gear, and then remove the spur, then remove the 4 spider gears and shafts, then pull the output gear out of the botton of the diff cup. The set screw is there so that you can get the cross pin out that holds the diff output in on the cup side.
